W
webego
I am no stranger to building PCs and have a reasonable experience of AV although a little outdated. I have recently immersed myself in all things HD in order to build an HTPC for my Dad who has just purchased a new 40in LED LCD HD TV (Sharp LC40LE700E). This was the second cheapest 40in LED LCD I could find at about £750 in the Jan sales (The cheapest was the LC40LE600E for about £600 but is only 50Hz compared to the 100Hz of the more expensive model).
I have researched the components for a mid priced (not bare bones but not getting carried away with myself) spec and wondered if anyone might offer their advice as to whether it will be up to the task of handling Freesat HD, Blue-Ray / HD movie playback (inc HD Audio), PVR, and Music.
So far this is what I have come up with:
CPU - AMD Phenom II X2 550 Black Edition (3.1)
Mobo - Asus M4A79XTD EVO, AMD 790X, AM3, PCI-E 2.0(x16), DDR3 1333/1600/1800, SATA 3Gb/s, ATX
(The idea of coupling these two is that you can apparently, if you are lucky, unlock the X2 to an X4 with mobos including SB750 southbridge)
Memory - 4GB (2x2GB) Corsair Dominator DDR3, PC3-12800 (1600), 240 Pin, Non-ECC Unbuffered, CAS 9, DHX
GPU - Sapphire Radeon HD 4670 Ultimate
HDD - 2 x (RAID 1 Mirror) 1TB Samsung HD103SJ Spinpoint F3, SATA 3Gb/s, 7200rpm, 32MB Cache, 8.9 ms, NCQ, OEM
TV1 - Hauppauge HVR 4000 (Can switch between Freesat and Freeview if any probs with sat)
TV2 - Hauppauge Nova HD S2 (For recording whilst watching TV1)
BD/HD DVD - LG GGCH20L (To hopefully take advantage of any cheap HD DVDs out there if that boat hasn't sailed completely yet)
PSU - NQ-4350GP-FL - 500W NorthQ Pacific II Fanless PSU, ATX 2.2 +80%+ Efficiency - 0Db
OS - Windows 7 Home Premium
Remote - Logitech diNovo Mini Bluetooth Handheld Keyboard (Get MC style remotes included with TV Cards but for keyboard & remote in 1, these look pretty special)
Okay, I have a couple of questions about this setup which hopefully some of you may be able to advise me on.
My family reputation depends on it!
Geoff
- You may have noticed that there is no case here. That's because my Dad doesn't want a typical HTPC case as they are too deep to fit on their shelves/cabinets (TV stand only 33cm deep) so he has asked for a tower. Anyone advice on a decent looking Midi Tower with an emphasis on quiet i.e included fans, ventilation, rubber mounts etc?
- I have researched the PSU but the spec says it only has 2 SATA connections. Can this be right or do they mean 2 cables with several actual SATA power connector on them?
- If I succeed in unlocking the other 2 cores on the CPU then I will need a decent and quiet HSF that doesn't break the bank. I have used Zalman in the past but wondered what the current thinking is on effective and quite HSFs?
- I have also not included an A/V receiver as I am a bit lost here. I have read Jameson_UK's thread on HD audio and think I have gotten my head around the basics but I get lost with how the GPU can pass the sound (I think in LPCM format) along with the video via HDMI to the receiver. Does this mean that the mobo audio chipset is not used at all? Also does this mean that the A/V receiver does not need to be able to decode TrueHD / DTS-HD MA as the GPU sends LPCM? i.e. is the GPU decoding the TrueHD / DTS-HD MA signal from the source and sending LPCM? This has confused my choice of A/V receiver as I am not sure if it must have TrueHD / DTS-HD MA decoding to ensure I have HD audio. Any suggestions for sub £200-250 A/V receivers with at least 2 HDMI inputs and the necessary technology for HD audio?
Geoff
