siross
Established Member
Hi all,
I’m looking for a bit of advice. I would like to upgrade my HTPC to make it quieter, boot faster and generally run faster to be honest.
The main uses my HTPC has is playing media (majority 1080p MKV and blu ray discs), listening to Spotify (streamed to rest of house) and also the occasional web browsing function.
My current set up is old:
Motherboard - GA-MA78GPM-DS2H
Processor - AMD Athlon 64 X2 Dual Core 5600+ 2.90GHz
RAM - 2GB Arianet Ram (DDR2 800MHZ)
HDD 1TB Hitachi Deskstar HDD and 2TB Samsung HDD
Antec Fusion 430 Case with 430watt PSU
I’m unsure about the fans that are in there currently but they’re not quiet, nor are the hard drives.
My current thinking is to keep the case and upgrade everything!
I’m on a budget of as cheap as possible and would like to go no higher than £200, anything less would be great. This needs to include a SSD for the operating system and XMBC/Spotify installation.
I was looking at this link: How I Built the Media Center of My Dreams for Under £310 | Lifehacker UK and it gives some pretty good advice, listing out recommended products:
CPU – AMD A4-5300 (£28.24 from Scan)
Motherboard – ASRock FM2A88X-ITX+ (Can’t seem to find this anywhere but there seem to be plenty of FM2 options Link) around £40?
RAM – Corsair XMS3 4gb DDR3 (£30.48 from Scan)
HDD – WD Green (3tb £75.96 from Scan)
Total = £174.68
The one thing missing there is a SSD, I really don’t know anything about them at all! Although this may take me well over budget.
Also, not included for fans, these will need to be as quiet as possible!
Any help would be greatly appreciated guys.
Thanks,
Simon
Total = £174.68
Thanks,
Simon
