HTPC to Toshiba 36ZP38 using VGA to SCART (RGB)
Discussion in 'Desktop & Laptop Computers Forum' started by FormbyMax, May 16, 2005.
  1. FormbyMax
    FormbyMax
    Having problems connecting my PC to the CRT Toshiba 36ZP38 using a VGA RGB to SCART (RGB) lead. The GPU is a XFX FX5500 card, using 66.93 drivers. When I connect up using S-video to scart, all is well (apart from the picture quality). I purchased i 15pin d-sub to scart (RGsB) lead from keene electronics. When i connect the lead to the SCART RGB on the TV nothing shows on screen. I have tried all the resolutions mentioned on thsi board and others, to no effect. I've also used Powerstrip to try custom resolutions as mentioned.
    Can anyone think of anything else I can try?
    TIA
    Max
  2. stlic
    stlic
    Feb 17, 2004
    750
    +19
    2 Points,
    As far as I am aware the Scart to D-Sub from Keene is one way, Scart --> D-Sub not the other way around.
    nVidia cards do not output a composite sync signal so even if the cable were correct it still wouldn't work with your card in it's current state. There is a, far more complicated, cable that you can make which adds composite sync to the signal on the fly.
