HTPC to Optoma H30
Discussion in 'Desktop & Laptop Computers Forum' started by GGB, May 20, 2005.
  1. GGB
    GGB
    Aug 23, 2004
    93
    Aberdeen
    Have been experimenting with using my PC with my Optoma H30 projector and have had one or two problems.
    I'm using Zoom Player with FFDshow and the Sonic Cinemaster codecs, when watching a PAL disc the picture doesn't seem to be very smooth. Have been trying to use Powerstrip to try and fix this but I can only find timings for NTSC playback. Anyone got timings for the H30 which are good for viewing PAL DVD's?
    Also when using FFDshow is it worth resizing the image to double that of DVD resolution to upscale the image?
    Any other pointers would be appreciated...
    My system consists of:
    ATI Radeon 9800
    P4 3.06 GHz processor
    1 GB Ram
    Thanks.
  2. stlic
    stlic
    Feb 17, 2004
    733
    +15
    Tried Reclock?
  3. GGB
    GGB
    Aug 23, 2004
    93
    Aberdeen
    Not aware of that program, is it a similar program to powerstrip in that it allows custom resolutions and refresh rates?
