Htpc To New Onkyo 705 Issues
smooth-op
HI
i ave been trying today to get my htpc which has hdmi out to the new onkyo 705 av reciever.
i get video feed but no audio
if i plug the hdmi cable directly to the tv i get audio
all the settings i assume are correct to accept audio on hdmi
sky hd works though hdmi - but i dont get dd5.1 i have to use optical for that *i would like confermation on that
thanks
Curly99
I'm sure it's a setting on the onkyo amp that need applying and as such i move this thread to the integrated amp forum where most of the Onkyo threads seem to be.
moved fromComputer systems forum
Curly
sp_harris
Yes sky only send stereo over the hdmi lead for some bizarre reason. You need optical for Dolby Digital broadcasts.
Sorry can't help with the other issue.
Racquel Darrian
You need to go into setup - assign input - Digital inputs
Change the source to HDMI.
ralphmalph
You also need to check that your HTPC can output audio over HDMI as most can not, they only send video at present.
smooth-op
the htpc does send audio as i recieve directly on the tv
just not the amp
iv set the input for the audio to hdmi aswell
smooth-op
Its Working !!!!!!!
Driver issue
Lovly to get dd and dts 5.1 awsome especially with this amp
100% now satified even though it will probably continue to impress me when finally some one will bring out a 1.3a hdmi connection for htpcs.
getting dtsHD-master and dolby truHD on my media centre will me aswome
any new on that ?
