HTPC software required?
Discussion in 'Desktop & Laptop Computers Forum' started by garyc, Oct 12, 2005.
  1. garyc
    garyc
    Dec 21, 2002
    895
    Jersey, Channel Islands
    +14
    Just built this htpc for running a crt projector. so far the spec is as follows:-
    pent4 3.0ghz, 512mb ram etc etc.....
    windows xp
    theatertek
    pb-tv100
    ati remote bob
    But what else do I need to get to do the video scaling/de-interlacig stuff inorder to get a nice picture on a crt projector?
    havn't got a capture card yet(sweetspot) for inputing an external source but will look at that later
    please help - going around in circles :confused:
    cheers
    Gary
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    well the PB TV-100 has a pretty good svideo input so you could use that before you decide to upgrade to the sweetspot. (I've had both the sweetspot is better but you might feel its not a significant enough improvement depending on source).
    You might want to dabble with ffdshow in conjunction with Theatertek.
    You might want to consider a digital tuner card like the Nebula digiTV.
  3. garyc
    garyc
    Dec 21, 2002
    895
    +14
    Hi Keith,
    Thanx - so will ffdshow do all the video processing that I'll need i.e scaling/de-interlacing while using theatertek as the dvd player?
    cheers
    Gary
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    ffdshow isn't a necessity but it helps improve the quality a significant amount especially on large displays.
    You'll find a lot of info and advice on using ffdshow on the theatertek.
    Its not however necessary for deinterlacing and scaling , your software and hardware will handle that as a matter of course. How good a job it does is something ffdshow can perhaps improve on.
  5. Barbarosa
    Barbarosa
    Sep 1, 2005
    73
    Try Media Portal It's open source and free! It takes a bit of setting up but lets you run your codecs of choice, dscaler, ffdshow etc...
    Also lets you catalogue your DVDs with IMDB info and, even better, plays FLAC files!
