HTPC slows down when connected to the internet
Discussion in 'Desktop & Laptop Computers Forum' started by CrispyXUK, Oct 28, 2003.
  1. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,751
    71
    Land of the Living, Essex
    +45
    Evening,
    Everytime I connect to the Internet after about 10 mins my HTPC slows down like a bitch on valium. So I CTL+ALT+DEL and I get DLLHOST.EXE using 91% so I Kill it. All is now well, what the fudge is going on it is driving me crazy please help if you can.
    PC Spec:
    Shuttle SS51g
    256 Ram
    Speedtouch USB (Green frogthing)
    Revo 7.1
  2. wolfeh
    wolfeh
    Feb 21, 2003
    500
    Ramsgate, Kent
    +10
    I dont know what dllhost.exe does or what its for, but it probably shouldnt be using so much cpu time.
    You could try blocking it access to the internet via a software firewall.
    Personally I use a program called Zone Alarm as a firewall. But I know not everyones a fan of it. But its easy to set up.
    Wolfeh
  3. Bursar
    Bursar
    Jun 29, 2003
    2,406
    63
    Cambridge
    +215
    Make sure you're up to date with all your Windows patches, and also your anti virus software.
    If these are all up to date, run a full virus scan across your PC.
  4. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Sounds like the Nachi virus.
  5. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Yup Naichi/Welchia virus - update windows and then run virus software (up to date)
  6. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    AVG is good and free if you need anti-virus software.
  7. Dominic
    Dominic
    Mar 2, 2001
    289
    Essex
    +6
    download stinger.exe. from McCafe and then patch the OS from MS then reboot then run stinger,
    , my mates win2k pc had this last week, and naichi had infected that very file you say is using all your CPU cycles.
    now its fine
  8. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,751
    71
    +45
    Right, I used Sophos to get rid of the virus but now windoows update always errors, and time clock will not sync
