pstones578
Established Member
- Joined
- May 8, 2006
- Messages
- 271
- Reaction score
- 9
- Points
- 92
I have just bought a new cpu / mobo / fan / RAM for my 8 year old HTPC. I kept the case / hdd's / PSU. Problem is that the 'new' system will not start and I think it's because my old PSU (380w) only has a 4 pin EATX12V (EPS?) cable instead of an 8 pin one that the mobo has. The fans / nic / etc all lamp up.
Can anyone recommend a PSU that is at least 400W that will fit the bill? Needs to power 3 sata hdd and also have a few molex too.
I'm looking at this one. Powercool 550W ATX PC Power Supply | Maplin
I really want to go and get this sunday so would apreciate it if someone could recommend I can buy tomorrow.
This is my old PSU FYI Antec SU380 power supply (in NSK2400 case) | silentpcreview.com
Thanks in advance.
Thanks in advance.
