HTPC: Please help...
Discussion in 'Desktop & Laptop Computers Forum' started by Hlynur, Mar 11, 2003.
  1. Hlynur
    Hlynur
    Dec 4, 2002
    37
    9
    Swanland
    Hi guys,
    I am thinking of upgrading my PC (long over due) and if I understand this correctly I can use it with a projector to produce a rather spectacular image. Problem is, I don't know computer chips from oven chips so I was hoping someone could tell me what I should be upgrading and for what, bascially :D
    At present it is a (from my sketchy memory):
    900Mhz AMD
    128MB memory
    28.6GB HDD
    Windows 98
    Some three year old graphics card (can't remember make, model, etc).
    The DVD-Drive is equally as old and has a maximum of 5 hardware region changes (obviously I need unlimited)
    and the fan is quite loud :p
    Should I just bin the damn thing? :blush:
    Can anybody help me with this? I'm completely lost in this strange new world, but it seems the next logical step in my DVD addiction.
    Thanks in advance :smoke:
  2. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Hi Hlynur,
    Welcome to the forums :hiya:
    Don't bin it !!
    Get an ATI Radeon card (7500 or 9000) and you'll be fine - you can unlock the DVD drive, maybe quieten it later, but it'll play DVDs fine through your projector with a custom resolution to match the panels in the PJ for a brilliant image.
    Do a search here for "powerstrip" and surf the HCPC side of the forum for lots of info. Some tweaking required, but it's lots of fun ! :smashin:
    All the best,
    Sean G.
    Kramer,
    Move to HCPC ?
    S.
  3. Kramer
    Kramer
    Moved to HCPC area - more information available here.
  4. Hlynur
    Hlynur
    Dec 4, 2002
    37
    9
    Swanland
    Thanks for the help theritz :smashin:
    Is it just the graphics card I need to change then? Doesn't processor speed matter?
    While I'm at it: what is the difference between ATI Radeon 7500 and a 9000? Price presumably :D
    I hadn't seen this HCPC part of the forum before (couldn't get past those projectors :p ) so I'll have a search through here.
    Thanks again,
  5. petrolhead
    petrolhead
    Mar 29, 2002
    4,778
    Newcastle
    +115
    The 9000 is a newer card and has not fan, so qieter :)
    You should just need a decent sound card that has S/PDIF out to feed the amp a digital signal.
    The processor should be up to the job, maybe worth adding an extra 128 Meg Ram
  6. Hlynur
    Hlynur
    Dec 4, 2002
    37
    9
    Swanland
    Thanks Petrolhead!
    I am having a new motherboard, 2.0GHz processor and more memory installed for a start, but I'm taking my time deciding on graphic and sound cards. :D
    Radeon 9000 seems the front-runner, just a question of whether to get the stand or the all-in-one card. I would want to be able to watch TV on the projecter, but I'm not sure how this compares to stand-alone TV cards :confused:
    For sound I just want something to feed my Yamaha VS10 the signal through the optical lead. Is Soundblaster 5.1 the best bet?
    Thanks again,
    Hlynur
  7. petrolhead
    petrolhead
    Mar 29, 2002
    4,778
    Newcastle
    +115
    I went for the M_Audio Revolution 7.1 sound card and have done away with my optical lead in favour or a digital. Well in fact digital was the only choice but as there is no difference then no prob.
    Dont know much about the all in ones aecept they always get rave reviews.
    I am just using my HTPC as a DVD player and feed a composite image from the back of my video. Very rarely use it though
  8. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    The Radeon 9000 isn't very good, a 9500 would be a much better choice. Also stay away from the AIW cards, if you want to feed TV through the PC go for Flyvideo2000 (see thread in this forum) and run Dcsaler.
  9. petrolhead
    petrolhead
    Mar 29, 2002
    4,778
    Newcastle
    +115
    Currious why you say this. I have a HTPC with one of these and it seems great to me :)
