either of the suggestions above should be ok. The Asus is good for overclocking (but is a wee bit more expensive), the Abit won't accept the newer range of cpu's should you want to upgrade l8ter.
An alternative is the Gigabyte GA-G33M-S2H which has hdcp. Not sure of the significance of this at the present time.
HTH
