HTPC mostly finished, now what software
Discussion in 'Desktop & Laptop Computers Forum' started by sticker, May 20, 2004.
  1. sticker
    sticker
    Jan 14, 2003
    1,153
    36
    Sydney, Australia
    Thanks to a lot of you guys I've now got my HTPC more or less finished hardware wise, but now I need to look at the software side. To summarise my hardware
    Accent 5 case
    Silnex PSU
    AMD 2500Xp O/C to 3200
    1gb ram
    DFI ultra mobo
    2 x Samsung sata 120gb Raid 0
    Nvidia FX5600 ultra with Zalman fanless cooler
    LG 4082 DVD
    I will be sending the signal via DVI to the Pioneer 503MXE plasma.
    Can anyone tell me what software I now need?
    Regards
    John
  2. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    Hi John
    do you just want to play DVD?
    If so then Theatretek is acknowledged as the best software DVD player.
  3. philipb
    philipb
    Mar 6, 2002
    2,029
    63
    Swindon
    +148
    Also add ffdshow for postprocessing - inproves the already excellent Theatertek picture quality. Instructions how to set up ffdshow are on the Theatertek support forum.
  4. sticker
    sticker
    Jan 14, 2003
    1,153
    36
    Sydney, Australia
    Hi Guy's
    Thanks for the replies
    Yep I want to pay DVD's so looking at what gives the best image and control and also to multi region the player
    Regards
    John
  5. AVMADMAN
    AVMADMAN
    I think that ffd show is only of benefit to people who are using crt based pj's or monitors. with theatertek.
    notice i said 'THINK' before everyone shoots me down in flames.... :p
  6. philipb
    philipb
    Mar 6, 2002
    2,029
    63
    Swindon
    +148
    Sticker is feeding a Pio 503MXE. I have the 433MXE, and TT + ffdshow is a great combi.
  7. sticker
    sticker
    Jan 14, 2003
    1,153
    36
    Sydney, Australia
    Guys
    What would you recommend as a "Wife friendly" user interface?
    John
  8. AVMADMAN
    AVMADMAN
    Maybe you could explain to me philipb what difference using ffdshow + theatertek has on the plasma. rather than just theatertek (when not using crt based monitors/pj's?)
    after taking my hcpc around to a mates house last night and assesing the difference on his Panny 50PV30B using ffdshow or not, i couldn't see any difference at all. (test disks AVIA, 5th element, Artificial Intelligence)
    Could someone clear this up please????
  9. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,731
    71
    Land of the Living, Essex
    +35
    did you switch ffwdshow on?
  10. MikeTV
    MikeTV
    Feb 1, 2003
    7,781
    Ealing, London
    +842
    I quite like PowerDVD XP from Cyberlink, and DVD Region-free from DVDIdle.com. They seem to work reliably. But I may be missing out on something quality-wise - not sure.
  11. philipb
    philipb
    Mar 6, 2002
    2,029
    63
    Swindon
    +148
    Its dangerous trying to generalise - given the range of kit in use. all I can say is that on my set up Theatertek goes from excellent PQ without Ffdshow to awesome with it. Noticeable improvement - better defined, sharper, clearer. Detail levels are higher.
    Ffdshow has a ton of things you can adjust - start with the settings recommended in the guide on the theatertek support forum and go from there.
    IMHO Theatertek is the king of software players - the aspect ratio control and adjustments are alone almost worth the cost.
    Given that ffdshow is free it must be worth a try. If it doesn't work for you then don't use it.
  12. Jeff
    Jeff
    Jul 13, 2000
    5,501
    Basingstoke
    +263
    One problem with ffdshow is that the TT mpeg decoder is no where near as good in software only mode compared to DXVA on, in software mode it suffers from i-frame pulsing and CUE problems. No matter how good ffdshow is, it is still an artificial enhancement and to use it you have to start from a much compromised position.
  13. Underscore
    Underscore
    Well, I used to have an HTPC and ran with ffdshow for a while on my LCD projector. The advantage (beyond the sharpening algorithms, which are a matter of individual taste) is, I believe, that Radeons use 4-bit fixed-point hardware to do the bicubic resize, whereas ffdshow use full floating point. Hence, using ffdshow to resize to a resolution where the horizontal and vertical resolutions are of the form n/16 from your display resolution results in better scaling than a Radeon used on its own.
    Personally, I did use a little sharpening, denoise, etc. and got a picture that, on most DVDs, I prefered to the non-ffdshow version. However, the lag introduced in the video relative to the audio annoyed me so I ended up going back to straight TheaterTek and, ultimately, a set-top player.
    _
  14. AVMADMAN
    AVMADMAN
    Thanks underscore for clearing that up
  15. mr_blah
    mr_blah
    Sep 24, 2003
    39
    9
    http://myhtpc.net/
