HTPC into a Denon AVC-A11xv
Discussion in 'AV Receivers & Amplifiers' started by m0v1em4n, Aug 4, 2005.
Tags:
  1. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    Hi all,
    I would like to connect my HTPC ( Nvidia 6600) to a Denon AVC-A11XV via the DVI cable, then output the signal from the Denons HDMI to a Domino 30H which as a native resolution of 1280 x 720
    Can any see any problem connecting a HTPC via its DVI output to an amplifier ?
    Any input on this subject would be appreciated :smashin:
    Steve
  2. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    Nope the DVi-D input is the only one that does not need a HDCP flag.
    The amp will apply HDCP before it comes out on HDMI though.
  3. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    Thanks Eddy Boy,
    Ordinarily I would go straight to the Projector from the HTPC, all though it would be nice to be able to use other sources if necessary,
    Presume that the Denon would allow the resolution to pass thought with out altering it?
  4. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    Correct it doesn't touch video resolution (be a bit of a pain with the DVD players if it did).
