HTPC Installations
Discussion in 'Home Cinema Buying & Building' started by richjthorpe, Jun 21, 2005.
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    Hi all,
    Are there any installers out there who install HTPCs along side the Plasmas/LCDs and AV receivers ?
    If you don't, is there a reason for that ? If you do, which systems do you use and how much are the systems ?
    Thanks all,
    Richie.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    13,982
    +2,786
    MAW does, I think Liam at Progressive does. I have quoted for such systems.
    Gordon
  3. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    If you've quoted for them, would you buy the system from an external supplier or would build it yourself ? Do you know what MAW or Liam do ?
  4. Gordon @ Convergent AV
    Jul 13, 2000
    13,982
    +2,786
    I quote for external supplier. I do not want to be involved in the continued support of a PC based product.
    Gordon
