HTPC,HT300 Link,and Powerstrip settings
Discussion in 'Projectors, Screens & Video Processors' started by bbutler, Dec 24, 2004.
  1. bbutler
    bbutler
    I'm just setting up my HPTC, and was wondering what people's experiences have been. I currently trying ATI x700 card, but I'm considering of changing to the GX6800. Any recommendations?
    However, my main questions is what is the best resolution to set my PC video output? I've seen some similar posts regarding the domino, but I'm not sure if those settings are applicatable to the HT300. I
    Thanks in advance
    Brian
  2. AD Roser
    AD Roser
    Aug 23, 2002
    280
    East Sussex
    +17
    Hi Brian,
    The HT300 Series has a native resolution of 1280 x 720, therefore you should set your PC output to that resolution. The display mode of the projector should then be set to "pixel to pixel" Refresh rate is usually set to 60hz but you can experiment ith 72hz for NTSC based material and 75hz for Pal. The result often depend on the hardware capabilities.
    Have Fun!
    Regards
    Alan Roser
    Managing Director
    SIM2 UK Ltd
  3. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    hi there Alan, do you have any idea how to set it to 75hz for PAL? Even when i set my DMF at 75hz with Catalyst/Powerstrip it still stays at 60hz. The sim2 seems to only change its refresh rate depending on the resolution. Is this correct?
    thanks
    CaM
