HTPC help!
Discussion in 'Desktop & Laptop Computers Forum' started by 9761, Aug 17, 2005.
  1. 9761
    9761
    May 16, 2005
    536
    HTPC is working yay!
    I have one problem.
    Im connected it to my Proggressive scan TV (Toshiba 32ZP48P) via component from the HDTV dongle that came with the graphics card (gigabyte 6600 256mb passive). But when I set up the screen resolution to 576p I am missing part of the screen and all of the task bar. Ive tried 576i, 480p, 480i, etc with no use.
    I want it to look like a normal desktop all planned out on the screen any ideas?
    6600 256mb graphics card with 77.72 drrivers
  2. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    This may be overscan. TVs normally don't show the bottom and top few lines of a TV picture, because broadcast is designed to live in a safe area. (obscure fact pal 576 lines is in fact 574 lines with two half lines. To check this take a look at a good monitor with no overscan and you will see the picture starts half way along the screen and ends half way along the bottom). In fact these undisplayed lines are what contained teletext.
    OK So with a computer screen this is bad. So with nVidia, you will see if you go to the full graphics properties there is a tab for Monitor and a button there for settings with facility to adjust your display by moving it up and down and shrink the vertical size, you can try fiddling there and see if that fixes it. Otherwise you can try and see if there are controls on your TV but its not very likely, though if you can't see the task bar that seems quite bad, usually it just clips a bit of the taskbar.
  3. 9761
    9761
    May 16, 2005
    536
    Ok,
    With I get a good picture with 480i and 576i now but when I put 480p or 576p it gets inlarged, overlay (whatever its called :confused: ). My TV accepts proggressive scan. Thanks
