HTPC help which one!!!!
Discussion in 'Home Cinema Buying & Building' started by aidanbrowne, Sep 20, 2007.
  1. aidanbrowne
    aidanbrowne
    Jul 2, 2007
    45
    Hi all after yet more advice and help.
    I almost have all the components for my loft home theatre setup but I have absolutely no idea when it comes to a p.c suitable for home theatre.
    I will be running the p.c, xbox360, virgin media through an onskyo sr605 amp with (Hopefully) one hdmi cable to a ph10 panel and canton speakers. Can you advise me what kind of p.c would work well with this system? Also what cable I would need to connect it to the sr605.
    I am hoping to spend somewhere in the region of £450-£700, I don't really use pc for gaming and can't really think of any more requirements other than lots of memory.
    I know this will probably seem very vague but any advice and help anyone can give would be greatly appreciated.
    P.s-Mods couldn't find a 100% suitable location for this post so if I have put it in the wrong place feel free to move!!!
  2. aidanbrowne
    aidanbrowne
    Jul 2, 2007
    45
  3. Sonic67
    Sonic67
    Sep 14, 2006
    46,425
    12
    167
    Home
    +25,485
