HTPC connected to Marantz 6012 via HDMI. Marantz sends Pre-out to Arcam A85/P85 for front three speakers. Marantz, Arcams (and sky box) all fed from one PowerPoint. HTPC, Xbox and TV all fed from a second PowerPoint about 1.5m away so probably a spur from the first.
I get a low volume, low pitch oscillating hum (from the front three speakers only) when the HTPC is doing something on screen. Static image, all is fine, however as soon as the image moves whether it be a movie or a scrolling info window in Kodi, the hum starts. It’s not audible above ‘normal’ sound through the speakers but it can be heard during any quiet scenes.
No problems with the Xbox which shares the same wall power socket as the HTPC.
It didn’t use to do this when they all shared the same socket.
Pretty much all the wires (four hdmi, 6 sets of speaker cable, coax phono, digit coax, several cat5e network cables) between from the front three speakers, TV, HTPC, Xbox, Dac (plugged into Arcam) to the Marantz and Arcam share the same space and also run down the side of the HTPC.
Anyone have any ideas if this likely to be a ground loop issue or an interference issue.
