HTPC Hard Drive
Discussion in 'Computer Components' started by HSC, May 11, 2005.
  1. HSC
    HSC
    Nov 23, 2004
    1,984
    63
    Coventry
    +172
    2.5" notebook hard drives are starting to look more attractive to me these days
    -large capacity (up to 100Gb)
    -high speeds (7200rpm)
    -SATA interfaces
    -low noise
    -low heat
    -falling prices
    but has anyone had any experiences of using them in HTPC setups...?
    anyone think it would be a feasible prospect...?
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    It is feasible, and some ITX cases use laptop optical drives and HDD's to save power. I presume most modern drives are quiet by default.
  3. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    yeah, but there's quiet and then there's quiet...
    The toshiba laptop drives got great writeups on www.silentpcreview.com a while ago, I think several people on there use them in desktop PCs/HCPCs, should be fine.
    what sort of prices are 100GB ones going for at the moment?
  4. SeanT
    SeanT
    Jan 28, 2005
    6,163
    Coventry
    +368
    It's good that people think Tosh laptop drives are quiet, as our Tosh laptops certainly aren't at all quiet - esp not the optical drives...
  5. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    yeah, to be fair its just the HDs I've heard are quiet, there's plenty more in a laptop that can make a racket!
  6. Duggy
    Duggy
    May 12, 2005
    38
    Oxford
    I've just built an HTPC with a WD Scorpio 80GB, 8MB cach 5200rpm notebook drive and I'm very happy with it. My case (Silverstone LC11m) didn't have any 2.5" drive mountings so I suspended it in a 3.5" bay using a "cats cradle" of elastic thread. It's basically inaudible from outside the case, and certainly MUCH quieter than a 3.5" drive would be (even quieter than a Samsung Spinpoint). You pay for the silence though - the cost per GB is quite high, and 80GB isn't that big for a home theatre PC...
    HTH,
    Duggy
