Hi Guys
Well sadly I'm putting my 3 XBMC's out to pasture, well eb*Y any way & I'll be sad to see them go. All other rooms in the house have PC's connected to Plasmas/LCD's to view films/listen to music etc.
I'm building an HTPC for the living room & I'm going to use a Intel Core Duo with 2Mb of Ram In an Antec Micro Fusion case. I'm basically looking for an Graphics card to suit. The system is primarily being built to play MKV files something my XBMC's won't touch.
Native resolution on my Hitachi P50T01UA is 720P, so i'm looking for a card that will support that & happily play MKV files, gaming will be at the same resolution. I could easily spend over £100 on a card that's not really necessary so your opinions are required.
Regards
Regards
