HTPC Gaming build spec - Advice needed
Discussion in 'Home Entertainment Computers' started by Maxell, Mar 1, 2013.
  1. Maxell
    Maxell
    Mar 1, 2013
    Hi I've never built my own PC before so any help would be much appreciated. I'm thinking about building my own Gaming HTPC to replace my ps3 and laptop. I have looked around the forums and come up with a spec i think that will more than handle my needs but, i would appreciate some feedback and advice from the experts on this forum. I'm not sure about the case or the gpu and i do want it to be as silent as possible. Also I'm going to connect it via HDMI to my Home Cinema system.
    Spec
    SilverStone Grandia GD08 Home Theatre Server Case
    Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W)
    Sapphire VAPOR-X HD 7950 OC with Boost Graphics card - 3 GB - GDDR5 SDRAM
    Samsung 840 Pro Series 256 GB Internal SSD Serial ATA-600 2.5" MZ-7PD256
    WD Green 3 TB Internal hard drive Serial ATA-600 3.5" WD30EZRX
    Pioneer BDR-207EBK 12x Blu-Ray Writer
    Corsair Builder Series CX 500w Modular '80 Plus Bronze' Power Supply (CP-9020059-UK)
    Cooler Master Hyper 212 Evo CPU Cooler
    Asus P8Z77-V PRO Motherboard (Socket 1155, 32GB DDR3 Support, ATX, Wifi, Intel Z77 Express, Network iControl, USB 3.0, SLI/CrossFireX Support)
    Kingston HyperX Genesis XMP X2 Grey Series 8GB (2 x 4GB) - 1600Mhz (PC3-12800)
    Be quiet! 120mm Silent Wings 2 Case Fan[/FONT]
