Quantcast
HTPC for beginners
MrPez
I'm after an HTPC but don't really know much about them.
I don't want anything for gaming, not into that, but I do have a lot of 1080 video that I want to play. At the minute, I have a samsung tv with dlna but its rubbish so I'm giving up and just want an actual computer to play the video and plug it directly into my tv with hdmi.
I also have a lot of music so would like a decent manager for that. Do HTPCs have built in amps or will I need to connect speakers through my existing amp?
So my question is, are there any good pre-built HTPCs or do I have to build one myself? I don't currently have a 3d tv but I would imagine I will before long so would like to future-proof for that.
Also, my laptop is pretty rubbish too so I was hoping to use the htpc for most normal stuff too and just remote desktop to it. Is that appropriate or would I be better to get a cheap netbook for other stuff?
If a self build is the best option, can anyone point me towards some decent sites that have suggested component lists?
Thanks!
nuff
I build mine myself and always use http://XBMC as the media player. If you go to the forums at XBMC.org you will find loads of answers that you may have.
This is my current setup......
Asus P5G41T-M LX G41 Socket 775 DDR3 VGA Out 8 Channel.. | Ebuyer.com
Kingston 2GB DDR3 1333MHz i5 Memory Module CL9 1.5V | Ebuyer.com X2
Intel® Core)
Sapphire HD 6450 AMD Radeon Graphics Card - 512MB - 11190-01-20G - Scan.co.uk
This is running very well playing all types of media including full blu ray rips
I hope this helps a little, Please ask if you need anymore help. :smashin:
