HTPC component choices
Discussion in 'Desktop & Laptop Computers Forum' started by m455954, Jan 12, 2003.
  1. m455954
    m455954
    Apr 20, 2002
    58
    +24
    I'm putting together the component list for my second HTPC. My first HTPC was contrained by AV rack space and so I ended up with an 'OK' solution for playback only. My VCR has just died and that means I can use the rack space it took up and do a proper HTPC with PVR and Playback.
    I'll mainly be recording from a Sky+ box, which can pump dolby digital out via optical SP/DIF, so I'm looking for a sound card with optical SP/DIF input. I'm going to be using an HTPC case (lmp-pc) so that rules out the Audigy Platinum as that requires a 5 1/4" front mounted bay, and I would really like to avoid having another box so the Platinum EX is out. Are there any outher good sound cards out there with optical SP/DIF input on the back plate? Obviously SP/DIF output is a must too (either optical or coax)
    My previous HTPC used its on-board nvidia nforce chipset graphics and a daughter card for TV-OUT. This did not give me any control of the overscan, so I ended up with a black border all around the outside of the desktop TV image. Which graphics cards allow you to modify overscan so the TV-OUT image will fill the screen?
    Is it better to have a seperate capture card or would an all-in-wonder or Ti4600 type solution with both TV-IN and TV-OUT be ok?
    Since I have a widescreen TV are there any cards that allow a widescreen TV-OUT resolution or am I stuck with 800 x 600?
    Thanks in advance,
    Mark Blackburn
  2. Mr. Wilby
    Mr. Wilby
    Dec 15, 2002
    641
    +16
    Free bump... Good questions which would help me too if anybody can answer :)
    Ta
  3. Beastie Boy
    Beastie Boy
    Take a look at this tool. http://tvtool.info/index_e.htm It should help to remove the border on the nvidia card.
    ATI cards require a registry tweak in order to enable the overscan option. At least they always used too, I'm not sure if this is now enabled by default. It any case, it is possible.
    Cheers, Beastie.
  4. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    as regards to the capture solution..... for a quality capture, i think most will agree that a separate capure card will be superior.
    ad
