HTPC case, under £70, under 150mm ?
Discussion in 'Computer Components' started by freeflyer56, Jan 16, 2008.
  1. freeflyer56
    freeflyer56
    Jan 16, 2008
    45
    Hi all..need a silver HTPC case , between £50-70 , under 150mm is a must, micro or full ATX, full size PCI, and preferably with a swappable or full size power supply or a decent (350w+) ATX v2 built in supply.
    Has to power a dual core E2160 processor, and standard PCI-X graphics card (8400GS). Not looking for masses of storage as its being networked to the upstairs PC which contains all the files.
    Was looking at an Antec NS240, but dont like the xposed drive bay.. and how tall is it? what about the fusion (is it really 140mm?)?
    Also looking at the coolermaster cavalier 4, but i dont think the power supply is swappable... is that strip on the front blue?
    Any optinion on either? What are my other options? will consider black if it looks kinda niceish :)
    ta...
    adi
