  • Black Friday Deals
    Visit our Black Friday page for our frequently updated, hand picked deals on TVs and other tech.
HTPC case and 8800gtx
Andy98765
Now that is an open statement if I ever heard one.
So we know the model of the card "8800gtx", but which one even a picture helps, but the BIG question is what size Motherboard are you using, ATX or mATX.
charly13
The card is BFG 8800GTX and the size is 27cm(i know is enormous..).The Mb i want to use is asus p5ql-e t think is standard atx.
The problem i have is i cannot find a suitable htpc case.
Maybe the antec fusion remote max is a very good choice but here were i leave i cant find it .Any other suggestions?
Thanx
P.s The antec fusion remote max would fit the card without any modifications?SLI possible?
vyruz18
I can't help you with your case selection, but do you have a specific reason you want to use this card??
I've had one myself and they're one hell of a card in both size and performance :eek:
However If you don't want to game etc I think this card is pure overkill for a HTPC.
They also tend to get very hot (around 70deg celcius if I remember correctly) which means it'll heat up your case and make all fans spin faster to cool it down --> NOISE!!!
charly13
The reason is that i have that card and i dont want to buy another one.The performance of this card is very good and i am willing to use the htpc for little gaming .
vyruz18
That's what I was thinking :)
I think you should sell this card, with the money you get from it you can buy a card which is smaller and has less heat problems but you will still be able to play most games.
Like I said this is an awesome card but I wouldn't want it in my HTPC (even if I had the space)
charly13
I think that the antec fusion remote max is the case i want (thanks HSC:)).
Do you know any online shop that sells it and ships to E.U?
qwales
I think i got mine on Ebay. It just fits my 260GTX which is also 27cm. If the power leads had been on the end of the card I would have had to remove the plate for the additional drive bays but it would have been a goer. It's really good but is a very big case.
charly13
Do you have any link from the store or it was a user?
How much it cost you?
