htpc and sky+
Discussion in 'Desktop & Laptop Computers Forum' started by nonikandola, Sep 20, 2005.
  1. nonikandola
    nonikandola
    i am seriously considering a htpc. But am unsure as to how my sky+box will fit in to the system. i wish to use ms media center 2005. as its sky+ im not to bothered about recording it to my pc, but am interested in upscaling sky+ and other video sources such as dvds and divx files.
    could someone tell me how i can capture sky to my pc with the best quality.
    i have a pioneer pdp435fde plasma.
  2. DaveP
    DaveP
    Sweetspot
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    What features of Sky+ are going to require use of HDCP? Those will will not be able to be used with a PC, there is no way to connect a digitial video input to a PC and most likey won't for some considerable time, if ever.
  4. philipb
    philipb
    Mar 6, 2002
    1,985
    63
    Swindon
    +132
    Robin - at the risk of being picky, there is of course SDI which I currently use.
    I think nonikandola is wanting to use the PC as a scaler, in which case DaveP is right. RGB scart into a PC using a Sweetspot capture card, then scaled and improved with Dscaler, is miles better than a straight RGB scart feed from the sky box into a plasma. I know it is because I've done it. Only trouble is you can't do it within MCE2005 :( So my advice would be forget MCE if you're going to be watching TV from Sky and use the Sweetspot instead.
    One word of caution - not sure about the inputs on the 435 - does the media box take a PC signal (VGA or DVI)?
    SDI is of course better still but much more expensive.
  5. DaveP
    DaveP
    He didn't mention HDCP, He said HTPC!
    Dave
  6. nonikandola
    nonikandola
    i guess i would use sky as an external souce from MCE. i would use prv freeview and dvds and stuff via MCE. i as well as scaling i like the look of the MCE interface
  7. David PluggedIn
    David PluggedIn
    Oct 14, 2003
    544
    +10
    Hi Nokikandola
    in that case have a look at MediaPortal , it is an open source project and has a much bigger range of hardware support than Windows MCE
