HTPC and NTL
Discussion in 'Cable TV & Virgin Media TV' started by bentleg, Sep 15, 2005.
  1. bentleg
    bentleg
    Aug 16, 2004
    328
    Notts
    +6
    Hi all
    I’m thinking of going HTPC soon, and after reading over that past few days I’m still stumped over something.
    I have an NTL box and was wondering can that be run through a HTPC so I can get all the channels and record them as well as pixel mapping.
    The thing that has thrown me off is all the TV cards are analogue or digital free view and I don’t know what inputs/ outputs are available. Can anyone advise me?
    I was thinking of this set up.
    link
  2. JonMace
    JonMace
    Nov 20, 2002
    2,542
    83
    Kent
    +207
    If you want to connect a STB you will need an anologue card, a digital one will not work. Connections will either be compersite or SVideo but no NTL box natively outputs SVideo so you would need a RGB -> SVideo convertor.
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Um, you can also connect an STB to a PC using RGBs, with a capture card like the Sweetspot .. I did at one time. :)
    Agreed though, a digital conenction isn't possible.
