HTPC and HDMI/DVI/VGA
Discussion in 'Desktop & Laptop Computers Forum' started by Daithi, Oct 9, 2004.
  1. Daithi
    Daithi
    Feb 12, 2003
    77
    Dublin
    Hi all,
    I'm in the process of building my first HTPC (will be running XP media center) and upgrading my projector to an AE700 around christmas too. I haven't bought a graphics card yet and would really like some advice as to what kind of output and cabling I should be looking for. The new panny doesn't do vanilla DVI, just hdmi and vga. I'll need about 15 metres of what ever cable I go for, so was wondering what you all would advise, should I look for a card that outputs hdmi/do a dvi to hdmi conversion/use vga/get a card with component and so save money as I already have theses cables? If i did use component do I lose the ability to pixel match?
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    You can feed an HDMI display from a DVI source, so any ATI or nVidia card will work with the Panny. You'll not find any PC card at present which has a HDMI output and none AFAIK are in the pipeline.
    You may want to take a look at this site for a comprehensive discussion of DVI/HDCP/HDMI. :)
    For a long DVI->HDMI cable I suggest you try The Media Factory, Joe doesn't list 15m cables but I know he does some very long DVI and I'm pretty sure you can get DVI->HDMI at that length .. they ain't cheap though, I paid £150 for a 9m DVI->DVI to ensure top quality and the ability to go up to 1920x1080i. Drop him an e-mail, he's very helpful in giving you the options available. :smashin:
  3. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    I use a van dam 10m svga cable (from farnell.co.uk) on my htpc and the picture is absolutely perfect. 1:1 pixel mapping is a doddle with powerstrip , the picture has been scrutinised extensively for noise and interference and absolutely none can be found. My cable is running right along side the power, svideo,composite and scart cables over a 10 m run probalbly the worst case scenario for a cable run and its still perfect. Bought a 10m dvi cable last week and compared it with the vga, I could not tell any difference at all and decided to stick with the vga cable rather thatn rip up all my floor again for no quality improvement as far as i could see ( ps. I have very good eyesight and am very critical of my picture quality so dont just think im a blind Ba****d who cant see the difference ).Another plus is that they only cost about 25 quid compared to 150+ for a dvi.
  4. Daithi
    Daithi
    Feb 12, 2003
    77
    Dublin
    Thanks for the reply lads, I think I may go the cheap route and stick with vga for a while at least, I hate spending lots of cash on cables.
  5. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I paid that sort of price because it's guaranteed to be able to handle up to 1920x1080i, lesser cables won't be up to that.
  6. philipb
    philipb
    Mar 6, 2002
    2,029
    63
    Swindon
    +148
    At the risk of being pedantic, you won't be able to build a HTPC using media centre. You cannot buy the OS separately. If you buy a media centre PC your upgrade possibilities may be very limited.
  7. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Um, as noted by someone in another current thread, you now can.
  8. philipb
    philipb
    Mar 6, 2002
    2,029
    63
    Swindon
    +148
    Wow, BG must be losing it.
  9. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    Cant see the pont of media edition as meedio is the mutts nuts. Even my missus can use it without a pc related disaster occuring
  10. Daithi
    Daithi
    Feb 12, 2003
    77
    Dublin
    I found this cable place if anyone is interested, looks like good value to me.
