htpc/amp comparison
Discussion in 'Desktop & Laptop Computers Forum' started by scouse, Aug 6, 2004.
  1. scouse
    scouse
    Jan 22, 2003
    273
    Balham
    +3
    If you build a htpc with a revo 7.1 sound card and a rotel 1066 5 channel power amp for example, what would be its peer in receiver terms?
    I ask because if you had a £400 budget would you spend it on a second hand reciever that would be connected to a computer as the source or go the sound card/ power amp route?
  2. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    me personally i would buy a reciever instead of just adding a power that if you wanted to add future kit but not pipe it through you pc then you have that option. :thumbsup:
