HTPC advice
Discussion in 'Desktop & Laptop Computers Forum' started by Abbs985uk, Jul 2, 2005.
  1. Abbs985uk
    Abbs985uk
    Apr 17, 2005
    59
    Birmingham
    Been thinking, is there some sort of HTPC setup whereby you can run all connections via HTPC to a PV500? Just thinking that in the long run a HTPC may be cheaper when HD DVDs materialise or Blu Ray.
    Also is it possible to connect Sky to a HTPC and do away with the Digibox? Will it affect picture quality? What kind of Media/Graphics card would enable this sort of versatility? Can you get HDMI connections a HTPC?
    Anyone know of any retailers/sites where I could see what kind of stuff is on the market?
    Thanks in advance guys, I know its all questions at the moment!
  2. Rambles
    Rambles
    Jul 14, 2004
    8,300
    UK
    +1,281
    No- you will still need the digibox but can connect it to the HTPC for post processing / recording. Sky do not (AFAIK) do a PC tuner card.
    Depends what type of connection / capture card you use
    You will need an analogue capture card and any graphics card.
    Common connection types are s-video, which give varying mediocre to good results, advanced connection is the Sweetspot RGB capture card whic should give better picture quality.
    Very uncommon, maybe non-existent. Can use a DVI to HDMI adapter though, (I think!).
    .: pluggedin.tv - home :.
    www.dabs.com
    www.ebuyer.com
    Media Computing with the style to look good in any living room
    to name but a few....
