HTML Editor.
Newton's Ring
Notepad.
Free in windows. Not very helpful I guess if you're a beginner but then I guess you can save existing webpages and edit them using notepad.
pandemic
Probably KompoZer or Nvu would be a good start. I don't use them just hear good things about them both WYSIWYG and free. I use notepad++ (not WYSIWIG)
KhalJimbo
I use Primal Script for VB ans Java stuff, pretty sure it can be used for HTML too, its a really good program although you do have to pay for it :thumbsup:
Shoka
When you get used to writing code - Notepad all the way.
Kompozer is OK - to me it didn't seem very Vista friendly? it kept crashing at pivotal points when using it, causing me to nearly throw my monitor across the office :thumbsdow although it seems a lot more stable on the Mac.
Not free but DreamWeaver is good as well.
Iccz
Notepad is good but I like to use Crimson Editor personally.
