HTIB vs AV
Discussion in 'AV Receivers & Amplifiers' started by titchy, Feb 22, 2014.
  1. titchy
    titchy
    Feb 18, 2014
    2
    4
    Nottingham, United Kingdom
    Don't bite my head off from this, I know that a AV receiver is better than a HTIB.
    My question is; how much better for music is an AV receiver compared to a HTIB?
    For example, I have a pretty old Samsung HTIB and the music is pretty loud and brilliant quality.
    Will I notice a big difference in music if I was to sell my HTIB (3ohm / passive sub) and replace it with my vx-r375 (6ohm / powered sub) which I've just purchased but cannot use due to not having the speakers yet.
    The only reason I ask this is because I'm a student and I'm already stretching my budget after paying £180 for the AV receiver and wondered if the £280++ in total is going to make that much of a difference for a small room.
  2. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,440
    The improvement in music quality will come from the speakers you buy to go with the receiver. If you buy a cheap budget sub/sat system then the gains in music may not be massive over your current system but there will still be some improvement I am sure. However, if you look to get some standmount based speakers then I feel the improvement will be more marked. Besides improved sound quality AVRs also offer far more connectivity and also easier/cheaper upgrades in the future.
