Htc one s - audio output
Discussion in 'Mobile Phones Forum' started by richie1965, Sep 10, 2012.
Tags:
  1. richie1965
    richie1965
    Apr 6, 2012
    3
    When I connect an audio lead (white and red audio connectors on one end and a 3.5mm standard jack plug) into the headphone socket on my htc one s phone with the adio connectors plugged into a stereo speaker system there is no sound output through the stereo speakers. The phone has a feature called beats audio on it which requires the supplied earplugs to be connected through the headphone socket in order for the beats audio sound enhancer to work.
    I have had many mobile phones before and Used to connect my phone to a set of external stereo speakers through the headphone socket as described above.
    I have contacted the HTC technical department but all they want to know is what type of stereo speaker system I am using. Can anyone tell me if i can do this as use external speakers regularly
  2. nvingo
    nvingo
    Nov 29, 2007
    3,089
    Cambridgeshire
    +675
    Would a bluetooth connection like this one help?
  3. richie1965
    richie1965
    Apr 6, 2012
    3
    Thanks very much NVINGO will try this device, looks good for a number of my devices. thanks again.
