HTC desire internal memory
Sulley75
Hi, does anyone know how I can see what's on my internal memory? I can see how much/little space I have, but I am fed up with having to delete apps from the internal memory or move them to SD. Either that or a way to download apps straight to SD instead.
Thanks in advance.
Johnny P
If you go to Settings > Applications you can see everything on your phone. Unless you have a rooted handset you are restricted as to what you can and can't delete.
If you root your handset and flash a custom ROM which is full A2SD then you will be able to store apps on the SD card.
Sulley75
Thanks for the response. I am now at a point where I can no longer download apps or update anything!! You tube can't update as it can't be moved to SD card. Phone contract runs out next may, I will certainly look for a phone with bigger internal memory then!!
rickinyorkshire
Bad design by HTC on this model and others released at a similar time. My g/f has the same problem, it also seems that camera photos are saved to the internal memory too with no option of saving directly to the SD card :facepalm:
