HT300+ and HiDef
Discussion in 'Projectors, Screens & Video Processors' started by richardS, Oct 17, 2005.
  1. richardS
    richardS
    Sep 14, 2004
    74
    I have an HT300 Plus currently hooked up to a denon 3805 and 2900 DVD and Sky+
    I wondered what, if anything, I can do to project HiDef picture (assuming that when Sky broadcasts in 2006...)? Is the projector capable of doing this with it's DVI input? I will no doubt have to change both DVD player and AV amp?
    Another stooopid question: What is HDMI exactly?
    Frightening the people you get on here eh???? :D
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    The 300 plus DVI input is not HDCP compliant so you would benefit from one of the DVI to VGA converters that Sim2 can supply.
    Jeff
  3. richardS
    richardS
    Sep 14, 2004
    74
    Jeff,
    Does this mean that I would get High definition picture (what line resolution?) if the source were right and I had the DVI to VGA converter? Just a little confused!!
    Many thanks
  4. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    Yes you would be able to receive HD material at 720p for example.
    Jeff
