Ht2xx/3xx ceiling mounts
ta1
I'm looking into a sim ht2xx/3xx projector.
What types of ceiling mounts are available for these?
Anyone with any experience in this area?
I assume flush mounting is OK wrt air flow?
Thanks for any help :)
RTFM
The Sim2 ceiling/wall bracket kit works with all the single chip models.
It's a very versatile kit allowing you to have the projector anywhere from close coupled to 1.25m from the ceiling. Can also be used for wall mounting the projector.
They cost about £150
Jeff :rtfm:
ratbert
I used a Unicol ceiling mount with my Domino 20, as the projector was white I was able to have the Unicol powder coated in white to match, looks better than being painted white by hand or sprayed white from a can! :smashin:
ta1
Thanks Jeff & Ratbert.
Jeff is there any specs for this bracket? Pictures/drawing showing screw holes with dimensions?
Ratbert, which model did you use? Or is there just the one on their site?
Regards,
Ta
Podcast: LG SN7CY Soundbar Review, Hisense 55U7Q, LG Nano90, Best of the Month, B+W Sigourney Weaver
