HT200 / i-scan pro display issues
Discussion in 'Projectors, Screens & Video Processors' started by mabar1, Jun 24, 2002.
  1. mabar1
    mabar1
    I am using a Sony DVD player, sending a component signal, doubled by the I-scan into the HT200.
    For some films, in parts (possibly on a horizontal panning scene?), the picture appears to 'spike', or digital artefacts appear.
    It also happens with an S-video output from Sky (via RGB conversion), again doubled through the I-Scan.
    Has anyone else experienced this, or can help me identify where the problem may lie?
  2. chips
    chips
    Dec 3, 2001
    2,404
    2NM S EGTF
    +25
    The output from iscan is via a "D" connector (VGA). To connect to an HT200 you need a special lead made up with "D" connector at iscan end and phono plugs at HT200 end, to go into the HT200 component phono sockets.
    If you are using a computer type lead going into the VGA socket on HT200, this could be your problem.
  3. mabar1
    mabar1
    Chips,
    Thanks for the response, but I've got a D sub->component lead as recommended by Sim2.
  4. chips
    chips
    Dec 3, 2001
    2,404
    2NM S EGTF
    +25
    Hi again,
    It's not that then, have you got the latest software installed? V1.2 I think.
    Try talking to Owl Video Tech Support.
