HT200 DM Software.
Discussion in 'Projectors, Screens & Video Processors' started by rolski, Oct 28, 2004.
  1. rolski
    rolski
    May 7, 2004
    234
    Cologne & Cheltenham.
    +4
    Please could someone let me know the latest software level for the HT200 DM, and where I can get it from.
    Thanks.
    Oh, and also, (if I have to update) is it easy to update ?
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    rolski,
    Latest vers. is 1.21
    Send me an email at: projectors@eurobell.co.uk and I will send you the latest firmware.
    You will need a 9 pin male to female cable. There will be a software wizard included which will tell you what to do.
    You can use any Windows platform including XP. Make sure you have the right
    Comms. port selected and the right Baud rate.
    Takes only a few minutes to download.
    Jeff :rtfm:
  3. rolski
    rolski
    May 7, 2004
    234
    +4
    Jeff,
    I have e-mailed you as suggested & have just seen that my current software version is "1.20 DM (P) 001".
    Thanks for your help.
  4. rolski
    rolski
    May 7, 2004
    234
    +4
    Jeff,
    Thanks for the software.
    A slight problem however - I've followed the instructions, and the flash download to the projector begins, but then I get the error message
    "An unknown error occured.
    File being downloaded:Gui_121DM.hex
    Flash download operation aborted."
    Any ideas ?
    Thanks.
  5. rolski
    rolski
    May 7, 2004
    234
    +4
    I've now also tried with a "twisted" cable.
    With the "untwisted", the download starts & gives the error message, and the "twisted" doesn't do anything.
    Looks like I've wasted some money on some RS232 cables here - and I'm asking myself if the software upgrade is actually worth bothering about ?
    Both my laptop & desktop are running Windows XP Pro with all the latest patches & updates, but I have no problems communicating with my TAG McLaren gear & other devices - could it possibly have anything to do with this ?
