HT1000 niggle!
Discussion in 'Projectors, Screens & Video Processors' started by mystex, Sep 21, 2003.
  1. mystex
    mystex
    Sep 15, 2001
    107
    Brighton
    For all you HT1000 owners out there or HT1000 demo'ers:
    Have you noticed that if you use any other remote control when the projector is in standby mode, the projector clicks as if its gonna start up - standby light goes from orange to green, (as though you press the on button and release it quickly). Then a few seconds later it clicks back to standby? It's not really a problem, but it does seem that the unit is very sensitive to infrared signals?
    Anyone else noticed this at all?
  2. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    Yep, I noticed that with the ones I had on demo. As I wasn't keeping them didn't look into it further but think I read something on AVS about how to cure it. If I find it I'll post a link.
  3. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,437
    Surrey. UK.
    +2,099
    As Messiah says, there's a way to stop this happening. Can't for the life of me remember how you do it (it's a menu option), but it can be done.
    Hopefully one of us will find the answer. :)
    EDIT: Found it here: http://www.avsforum.com/avs-vb/showthread.php?postid=1955695#post1955695
    It says:
    "If you go to setup page 4 and check idle mode the projector will no longer 'click' when some other device remote is fired."
    Gary.
  4. mystex
    mystex
    Sep 15, 2001
    107
    Brighton
    Thanks for looking guys, I shall have a play around in the menus and see if I can spot anything....
  5. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,437
    Surrey. UK.
    +2,099
    Here's a bump just in case you missed my edit...
  6. mystex
    mystex
    Sep 15, 2001
    107
    Brighton
    Thanks alot Gary works a treat! These forums are great ain't they:smashin:
  7. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,437
    Surrey. UK.
    +2,099
    They certainly are!
    Glad to be of help. :)
    Gary.
  8. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    Well done Gary. I was gonna have a look this pm (been out all morning) but you've saved me the trouble :smashin:
