HT-XQ100W - Help - Where can I buy one??
Discussion in 'Home Cinema Buying & Building' started by Buzzard, Aug 30, 2007.
  1. Buzzard
    Buzzard
    I have been searching incessantly for the white version of the HT-QX100 to go with the LE40R86WDX as I think they go together perfectly. But it is only available in black in the uk and even then seem to be discontinued. There seem to be lots available in Poland quite cheap too but I can't understand the language and therefore the validity of the sites either. There are other countries like germany and holland that do the 2.1 version but not the 5.1. It is very confusing!
    Does anybody know where I can get my hands on one?
  2. Iain_tk
    Iain_tk
    Hey,
    Iv also been looking for the white version of the HT-XQ100. Iv found some sites on the internet were you could get it from hong kong, czech, poland, and romania. I very nearly had one brought back from the czech but some complicated things happened so it couldnt. Sites cnet have said that a white 5.1 will be avalible in UK but these reviews were dated march 2006 also will the XQ100 get replaced buy the new HT-X250R ??
    Ian K
