HT-TX35R / SH53M noob Q?
Discussion in 'Home Cinema Buying & Building' started by Pigbristle, Sep 2, 2007.
  1. Pigbristle
    Pigbristle
    Jul 29, 2007
    23
    Can any of you guys clarify for me some questions I have concerning the HT-TX35R
    http://www.dabs.com/productview.aspx?quicklinx=4GSY
    And the SH55M/SH53M?
    http://www.dixons.co.uk/martprd/sto...u=870877&page=Product&fm=null&sm=null&tm=null
    First off, am I right in saying the DVD that comes with the HT-TX35R is just a DVD player & not some integral part of the sound system?
    Because I was thinking of replacing the DVD with said SH55M/53M model.
    Would the HT-TX35R just work the same with the SH53M replacing it?
    Can you also confirm that the SH53M can play DVD-R for me, or does the machine have to be multi region to do this?
    All I want to do is record TV & play the odd DVD film with decent sound.
    thanks for listening & your replies are much appreciated
    ps:don't mean to double post but was also putting this in the SH55M forum
    too, if thats ok?
  2. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    well,if you are planning on buying a dvd recorder,and a dvd home cinema system,i would say,forget the samsung HT TX35R,and buy a system without a dvd player.
    and yes,the SH53M,will play DVD-R.
  3. Pigbristle
    Pigbristle
    Jul 29, 2007
    23
    Thanks for the reply RottenFox
    I have been looking round for just a system without the DVD player, trouble is I like the matching blackTallboy speakers to go with my sonon to be Samsung TV.
    If you know of any 2.1 or 5.1 (only realy botherd about the 2 front ones being Tallboy) I would love to hear from you?
  4. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +4,289
