HS50 Wall mount bracket/shelf
Discussion in 'Projectors, Screens & Video Processors' started by onefivenine, Jan 18, 2005.
  1. onefivenine
    onefivenine
    Nov 5, 2003
    3,351
    Edinburgh
    +647
    Would this wall bracket
    http://www.screwfix.com/app/sfd/cat/pro.jsp?ts=72496&id=39988
    with either a wooden or glass shelf attached, be suitable for an HS50?
    Pssible shelf - http://www.diy.com/diy/jsp/bq/produ...649&entryFlag=false&PRODID=133994&paintCatId=
    I'd be mounting this on hollow plasterboard wall using plastic toggles/rawlplugs, something like these
    http://www.screwfix.com/app/sfd/cat/pro.jsp;jsessionid=JB21AZENIQNW3CJO2C1SIIQ?ts=72375&id=38258
    Also can anyone tell me the width and depth dimensions which the HS50's actual 'feet' take up... if you see what I mean... ?
    Thanks.
  2. xaser1066
    xaser1066
    Hi, I have my HS50 sitting on a shelf mounted to a plasterboard wall. I am using silver effect SPUR shelf brackets and supports from B&Q with a 400mm deep shelving board. The front of the pj is level with the shelf front and this leaves about 50mm at the rear for cabling (although it could be reduced to 30mm if required). The front feet are set back about 80mm from the front of the unit - so if i swashed it up against the wall the shelf depth could have been about 300mm. Hope this helps. I have attached a picture - if it works.
    Cheers, Jason.
  3. UrbanT
    UrbanT
    Jan 6, 2002
    12,873
    Aldershot, Hants
    +3,034
    Also using bog standard shelves from DIY places, screwed to plasterboard wall. Works perfectly. I would recommend a minimum depth of 33cm for your shelf
  4. MAD ANDY
    MAD ANDY
    Nov 12, 2003
    304
    Cheshire
    +9
    do what I did and make a wall feature come pj shelf in seconds :D
    check the link in my sig for all the pics, but here is an idea, made it for £6 :D
    [​IMG]
    [​IMG]
  5. zoolap
    zoolap
    Oct 2, 2001
    594
    Warwickshire
    +7
    xaser - your setup looks nice, but the amount of space available around the dvd player and amp can't be good for them. I see no vents on side of the amp, so dvd player must be taking most of the heat.
  6. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    Ingenious idea MA.
    Can't make out the picture in the frame, is it a picture of your PJ? ;)
    ...PJ
  7. xaser1066
    xaser1066
    zoolap - thanks - true there are no vents on the sides of the amp, but the dvd player is quite short and only blocks a few slots. i did worry about over heating but after 4 hours solid use it is only warm - not hot. the amp is a digital amp which uses switched current instead of constant current like a linear amp (a bit like the difference between switch mode power supplies and linear power supplies, the linear supply is less efficient and turns more electricity to heat because the transistors are on all of the time, where as switched mode is fully on or fully off). if there are problems i can spread things out a bit more - it is quite flexible and child friendly ie. they can't touch it!! cheers, jason.
  8. onefivenine
    onefivenine
    Nov 5, 2003
    3,351
    Edinburgh
    +647
    MAD ANDY - nice work!
    I need to calculate the ideal height now and have a question for you HS50 owners...
    Is the centre of the projected image in line with the centre of the lens, when using zero lens shift? I'd like to minimise any distortion due to manipulation as much as possible.
  9. MAD ANDY
    MAD ANDY
    Nov 12, 2003
    304
    Cheshire
    +9
    sorry mate, you've lost me? :confused: :) I dont actually have any pics of the pj DOH but you can see more pics here (ignore 1.3mp cam quality though):
    www.aqvr74.dsl.pipex.com/pj
    cheers mate :) Do you mean like this?
    [​IMG]
    [​IMG]
  10. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    ...ignore me, just my weird sense of humour
    I imagined your drop down shelf to be a picture frame when in the upright position
    kinda thought it would have been funny if the picture was of your PJ....
    bit like when I went to a friends house and beside the fireplace was a picture of the fireplace...
    obviously not that funny... :suicide:
    ...PJ :)
  11. MAD ANDY
    MAD ANDY
    Nov 12, 2003
    304
    Cheshire
    +9
    lol no was quite funny actually :D now I get ya! Sos mate, my mistake, I was thinking of frame as in HTML frame... DOH!!!!!
    yeah I get ya! ;) funnily enough a mate who has done the same thing has actually used a picture to do it on... of a flower DOH!!!!
    but yeah that would be quite comical of a pic of the pj itself PMSL!!!!! :D
  12. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    ...woz it an iris? :D ...PJ
  13. MAD ANDY
    MAD ANDY
    Nov 12, 2003
    304
    Cheshire
    +9
    no a crysanthanum... chrysaanthamum.... chriserm... a flower!
  14. kstandsteve
    kstandsteve
    Apr 4, 2005
    58
    11
    Mad Andy,
    WOW!!!
    What a great idea that wall mount!
    Your mate with a flower picture sounds a bit gay??
    Steve.
  15. MAD ANDY
    MAD ANDY
    Nov 12, 2003
    304
    Cheshire
    +9
    FPMSL!!! aye Steve he is a little on the batty side lol :rotfl: :hiya:
    If you are interested in the mount idea, let me know, it was all my idea ya know ;) :cool:
  16. theendisnye
    theendisnye
    Oct 11, 2004
    63
    I got a very nice Vogel's wall mount for my projector, it came free when I bought the projector and had literally just come out on reflection it was ideal for my situation - cost new is £130.
    Steve
