Hs50 Vb!!!
Discussion in 'Projectors, Screens & Video Processors' started by tazpc, Sep 21, 2005.
  1. tazpc
    tazpc
    Jul 13, 2002
    252
    NORTH BUCKS
    +4
    Hi Guys thanks for the info on the HDMI and Pioneer 868 to HS50.
    In the end replacing the 5m Profligold HDMI with the 5M QED solved the problem.
    A second issue that I am having is very suspicious of VB an issue that I thought the Sony did not have.
    On light coloured scenes I see vertical lines from normal viewing distance
    PAL and NTSC.(720p 1080i and component) Close to the screen i see nothing.
    they are about an inch apart. As I move my viewing position I can see them across the whole screen.
    System comprises of Poineer 868 QED hdmi(5M) Sony HS50 (latest firmware)
    OWL grand cinema Tab tensioned screen.
    Ben at Discount TV has been extremely helpful and agreed to swap out the HS50 but has anybody got any suggestions prior to doing this.
    Many thanks Tariq
  2. ROne
    ROne
    Dec 21, 2000
    780
    +7
    I've not seen anything as yet to convince me that VB is completely banished, model to model.
    If you have none, you are just lucky...
    You could try a filter or two, they can sometimes subdue the lines a little. Other than that I don't know anything about the HS50s service menu capability.
    Is the VB worse on any one of the inputs (HDMI, COMPONENT, VGA?)
  3. tazpc
    tazpc
    Jul 13, 2002
    252
    NORTH BUCKS
    +4
    Its the same on all inputs.
    Fully calibrated with DVE.
    What settings on PJ would affect it anyway?
  4. tazpc
    tazpc
    Jul 13, 2002
    252
    NORTH BUCKS
    +4
    Is there any other artifact that could give the appearance of VB.
