HS50 - Time to buy?
Discussion in 'Projectors, Screens & Video Processors' started by guyvert1, Mar 8, 2005.
  1. guyvert1
    guyvert1
    Jul 11, 2004
    395
    +9
    Been looking to get a decent LCD again after trying out CRT and although finding pic is superb, I can't live with the industrial size!..
    Had my eye on the HS50 (I had a HS10 yrs ago).
    Before xmas it was around £1500 cheapest, and I'm suprised that this still seems cheapest (Gultronics), has anyone found it cheaper?
  2. Dwayne Dibley
    Dwayne Dibley
    Dec 1, 2004
    1,026
    Right Here, Right Now
    +470
    there is a major shortage of these units.... my order with Gultronics was placed on 28th Jan, not best pleased (this is no reflection of Gultronics, they've been very obliging)..... there are a few of us on this forum who are awaiting new stock....
    Some other 'stockists' have said they'll do a price match, but without any in the UK its a kinda moot point. (Nexnix did have 8 units about a month ago, but they wanted 1399+vat)
    Also bear in mind that any new stock "should" have the updated firmware. (Don't quote me, I'm not sure where I read this).
  3. guyvert1
    guyvert1
    Jul 11, 2004
    395
    +9
    Oh, didnt realise they were still low on stock!!.. I suppose that allows the RRP to still be pretty high for something thats been out a good few months :( Was tempted to get the HS51 from Land of the rising SUN :)
  4. seanm
    seanm
    Mar 1, 2002
    1,284
    48
    +44
    Nexnix had stock last week.
    But they were not prepared to sell them, they were shipping them all back to Sony.
  5. Beastie Boy
    Beastie Boy
    In a way, I'm pleased to hear this. Does that mean that Sony are not allowing any more units to be sold without the upgraded firmware and possible prism block assembly replacement?
    If so, at least I can be confident that mine will be updated when it arrives.
    Cheers, Beastie.
  6. seanm
    seanm
    Mar 1, 2002
    1,284
    48
    +44
    I think its Nexnix's decision.
    IMHO, Sony would not give a toss.
  7. hebawom
    hebawom
    Apr 16, 2004
    187
    19
    Matlock
    What is this prism block assembly replacement?
    The new firmware gets rid of the blanking issue through HDMI, is this correct?
  8. seanm
    seanm
    Mar 1, 2002
    1,284
    48
    +44
    I think the prism block assembly is the block where the three colors come together and then are projected out of the lens and onto your screen. It might have something to do with the pixel misalignment people have been complaining about.
  9. maj74
    maj74
    May 27, 2002
    724
    Ipswich
    +23
    These updates that can be done to this machine now, does the machine HAVE to be returned to the dealer it was bought from, or sent to Sony direct, or takej to a Sony Centre to be passed on to Sony?
    Just trying to avoid hassle!!!
  10. Tempest
    Tempest
    Jan 11, 2002
    8,769
    Horley, Surrey
    +4,542
    I hope so, as (though it did not seem to be affecting current owners enjoyment) personally 3 pixels misconvergence is just unnaceptable for a machine that's supposed to be at the top of the current big name machines.
  11. Edgeyboy
    Edgeyboy
    Jul 31, 2000
    3,565
    Cambridgeshire
    +180
    The update is only for the 720p blanking issue. It will be available in the UK in 2 weeks time.
    If you have bad panel alignment, then that is an entirely seperate issue: There is no recall / update for this issue. You have to bear in mind that a certain level of "tolerance" is allowed by SONY and unfortunately, this may not coincide with you own level of "tolerance".
    SONY may choose to replace an optical block if the alignment is bad enough at their own discretion. They may also check the alignment when/if you send in your HS50 for 720p update.
    Fortunately, the panel alignenment on my HS50 is very good after having 2 previous models that weren't...
    HTH
  12. Tempest
    Tempest
    Jan 11, 2002
    8,769
    Horley, Surrey
    +4,542
    Did you send the other 2 units back as faulty due to panel alignment?
    The topic about how many dead pixels before you can send it back has been done to death.
    But, I've never heard what constitutes a faulty model when it comes to panel alignment.
    My personal opinion (and I know others will disagree!) is that the RGB dots should at least (to some extent) overlap for a single pixel. eg: if it's OVER 1 pixel out then it's faulty. and you will not get the correct colour for that pixel as the colours will never overlap on that spot.
    Even if it was 3/4 of a pixel out, then at least 1/4 of that pixel will be the correct colour.
    I don't know where you stand regards a shop and this issue?
  13. Edgeyboy
    Edgeyboy
    Jul 31, 2000
    3,565
    Cambridgeshire
    +180
    The dealer who sold my HS50 is excellent and values my custom and swapped them over. SONY were not directly involved.
    I think the key here is to use a local dealer who will check it before it goes out or find a sympathetic internet dealer and prearrange a swap over if you are not happy.
    I would imagine SONY themselves could be very tricky if you couldn't resolve it with the dealer.
