HS50 Brochure
Discussion in 'Projectors, Screens & Video Processors' started by PBL, Dec 23, 2004.
  1. PBL
    PBL
    After searching for about an hour looking for confirmation on the inputs for the HS50, with some retailers claiming it having scart & dvi and some saying it doesn't, plus sony.co.uk not even mentioning the HDMI in their technical specifications (not exactly faith inducing):
    > Connectors
    > 4 Pin (Y/C) In S-Video
    > Component Compatible YES
    > Computer Input 15 pin D-sub
    > Dimensions
    I came across a HS50 brochure which seems quite definitive:
    http://presentation-systems.co.uk/pdfs/sony-vpl-hs50.pdf
