Have you considered the sim2 products, maybe on par (almost) with your crt and longer bulb life as well. the domino is only 3.5 k, a cheap personal loan would be payed off by the time the pj needed a new bulb.
I haven't really looked at the Sim2 offerings. I realise that LCD/DLP technology is moving along at a pace that means todays hot PJ is tomorrows doorstop. Therefore I wanted to get an interim PJ that will allow me free up the room's floor space.
The Barco sits in the middle of the room taking up a prime location. This means I can't put down new carpet and for this and other reasons I mentioned earlier the Barco will have to go.
So, Cheap but still good interim PJ??? I have a family member who works for Sony which means I can get a great deal on anything Sony. I don't abuse this but this woruld be one of those times to take advantage.
HS20 is obviously a contender then.......However... AE500 from Price Japan is far cheaper than a staff discount Sony (actually an HS20 on staff discount is not much better than an HS20 pricejapan deal, though has full UK spec & warrantee).
To add to the fun, I have a bar traversing the room that a short throw PJ would be able to sit on, an HS20 won't and will need to be suspended from my 18ft high ceiling
. You can get a short throw lens for the HS20, but Sony UK don't stock them so I'd have to import that myself adding to the cost.
Mark Grant also suggested a S/H D-ILA from the US which I haven't ruled out but I'm worried about noise containment and fixing and anamorphic lens infront of it gives me worries. Also, only 1000hrs bulb life.
So Options are:-
1/ Keep Barco on floor, but try and improve how it looks there. Accept it's intrusion, rick of child damage and lack of X-Box games.
2/ Cheap AE500 Import (Not sure on throw distance as don't fancy this option)
3/ Staff discount Sony HS20 + Imported Lens Plus
4/ Benq PE8700 short throw DLP from Ivojo for £2850(Incl VAT) which isn't THAT much more than the Sony option once I add the Lens to the Sony price. VERY good reviews too.
5/ Import S/H D-ILA from US & Anamorphic Lens & Hush Box.... (SO many things to go wrong or cost more than expected there)
Leaning toward the HS20 still, this is only an interim step for say, 2 years top remember.
Hope this helps explain my uncertainties,
Cheers,
Mark.
