E
eugdog
How does the HS20 by sony compare with the NEC HT1000- assuming a progressive scan DVD player (ie ignoring the built in prog scan on the NEC 1000)
maybe your sig should read 'Resolution Junkie' !!!Originally posted by Kramer
Yes, the HT1000 is better in many/most respects but personally I find the resolution to be unacceptable.
All said before in my mini review in my sig.
I agree, but for the opposite reason in a way.Originally posted by sneaky
The only thing I would say, is if you are buying a DLP make sure you watch a full movie on it.
