HS20 too loud?
Discussion in 'Projectors, Screens & Video Processors' started by Mr.D, Aug 5, 2004.
  1. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,210
    How loud should an hS20 be?
    Mine seems to be a bit on the over-revved side.
    This seems to be commonly regarded as a quiet projector.
    I'd have to say mine is a bit noisier than I was expecting:its definitely noisier than the ae100 I had previously: lamp is on low and high altitude mode is off I also run with the iris closed down .
    Any ideas?
