Quantcast
HS20 Software
T
terminal santa
Has anyone had any joy downloading the Image Director software for the HS20 - or are there any third party (homebrew) apps which can be used to control the finer aspects of the projector?
Santa
T
terminal santa
Yay
To anyone who is interested, found Image Director software buried on japanese site, here
Gonna have a play!!
Santa
S
spacekdet69
hi
just curious as to what this actually is, i cant display jap langauge... well im interested in knowing all about it,, so let me know how you get on.
best wishes and regards
nick.
homethx
Just down loaded it from link
What does it do ?
Mr.D
I'm hoping it lets you apply colour correction LUTs to your HS20 interactively whilst its displaying a suitable test pattern,
Failing that I'm hoping you can somehow profile the response curve of your projector and apply the inverse LUT to remove kinks.
Failing that give Gordon a ring!
T
terminal santa
The software appears to allow the user to create new gamma setting which can be saved on the pj, allowing combined or individual RGB gamma curves with three different curve profiles....
Gonna give it ago tonight with the THX test pattern (as i dont have any other test images) - any suggestions?
Santa
Mr.D
Does it let you create your own ?
Is it a simple gamma adjustment or can you define arbitrary curves?
T
terminal santa
It just seems to have 3 curve profiles, ranging from slight to deep (not very technical terms I know) - I think the real benefit maybe in the individual RGB curves where you may be able to turn down green if it is too intense
Santa
Mr.D
Santa
Nope having looked at this software all it does is allow you to vary gamma and restrict its effects by limiting the curve or varying the pullpoint.
It won't let you define arbitrary curves with plotted anchor points ( ie its no good for profiling).
