Hi Guys,
I have received my HS20 and I am mad keen to get it setup. Plugged the DVI cable from the Radeon in the HCPC to the projector - I get absolutely nothing. Unplug DVI cable and plug a monitor into the VGA port - screen comes on the monitor. Plug the DVI cable back in and absolutely nothing from monitor otr projector.
What I actually want is to plug the dvi into the projector from radeon and get rid of the monitor - presumably - it is a case of setting the DVI port to primary device - but I just cant see it.
Something simple but just missing it - help and advice would be greatfully appreciated.
Chris
Chris
