HS20 RGB scart ?
Discussion in 'Projectors, Screens & Video Processors' started by homethx, May 21, 2004.
  1. homethx
    homethx
    Feb 24, 2002
    728
    +78
    Will the keene RGB to component transcoder work (SYNCBLASTER RGB2C) OK with my projector(HS20) has anybody used this model ?
    As this seems the cheapest option to get scart to this projector.
  2. homethx
    homethx
    Feb 24, 2002
    728
    +78
    What! no body using a scart to YUV transcoder and HS20 even maplin sell one. Can some body help will it work or not and the other thing is will a non RGB scart signal give a picture ie VCR.
    :cool: if you reply
  3. ailean
    ailean
    Do a search, this has been in at least 2 threads here this month. ;)
  4. homethx
    homethx
    Feb 24, 2002
    728
    +78
    I've read all the thread but i don't think anybody is using them. I just want to know how people are getting on with them . IE can you plug in a two into one scart adaptor for say xbox and sky+ and get no interference on screen
  5. homethx
    homethx
    Feb 24, 2002
    728
    +78
    closed got my answer from OcUK
  6. sneaky
    sneaky
    Dec 14, 2003
    348
    16
    North East
    And was that answer a NO.
    Chris
  7. homethx
    homethx
    Feb 24, 2002
    728
    +78
    I'll tell you once i get it .
